rear wheel bearing
Old Apr 12, 2007 | 08:41 PM
decipha's Avatar
Default rear wheel bearing
im trying to replace the rear wheel bearings on a 96 3800 series and can't get the axles off. The chilton book says its help in by a c clip.. i took the diff cover off and don't see any clips. It also says to remove the bolt holding the pinion shaft in, the pinion shaft doesn't have a BOLT! it's held in by what looks like a pressed shaft. I know some one must have replaced the wheel bearings before... all help is greatly appreciated.
Old Apr 12, 2007 | 10:23 PM
Default RE: rear wheel bearing
There is a bolt on the side of the differential carrier that locks the cross shaft in place, Remove the bolt and you should be able to tap the cross shaft out. Then push the axles in toward the center of the housing and the C clips become exposed, now remove the C clips. Be careful not to damage the reluctor wheel on the outside of the ring gear, otherwise the ABS won't work. Now pull the axles out
Old Apr 13, 2007 | 02:13 AM
decipha's Avatar
there is no bolt.... the chilton book shows a bolt my differential shows no bolt.. it looks like its pressed in... any one else??
Old Apr 13, 2007 | 05:04 AM
decipha's Avatar
is that the little bolt at the bottom? looks like maybe an 8mm ??
Old Apr 13, 2007 | 02:01 PM
Yes.
Speedfreak02
Aug 14, 2012 10:36 PM
auto
Feb 26, 2012 06:52 PM
Barbs 2001 SS
Oct 17, 2010 09:56 AM
kisk
Apr 19, 2008 07:04 AM
decipha
Nov 3, 2006 03:15 AM
