Rear wheel bearing -- can I remove the axle myself?
Old Apr 10, 2008 | 07:19 PM
kisk's Avatar
Default Rear wheel bearing -- can I remove the axle myself?
1995 Camaro V6 3.4L
I know I need a bearing 'puller' to get my rear wheel bearing off of my axle, but can I pull the right axle out w/out removing the bearing, or does the bearing block the axle from being pulled out by hand? I'd like to be able to just do this part myself if possible and then take it to a shop and have them pull and put on a new bearing. What's a typical cost to get one pressed on?
Any tips/cautions when doing this procedure myself?
Oh, and what size is the differential pinion shaft bolt? 7.5mm?
Thanks!
Old Apr 19, 2008 | 07:04 AM
kisk's Avatar
Default RE: Rear wheel bearing -- can I remove the axle myself?
kk, I figured it out... just pulled the axle out then used a bearing puller to get the oil seal/bearing out.
Speedfreak02
Aug 14, 2012 10:36 PM
Dznuts
Mar 18, 2012 06:33 PM
auto
Feb 26, 2012 06:52 PM
4thknd95z28lt1
Mar 29, 2011 08:02 PM
decipha
Apr 13, 2007 02:01 PM
