wheel bearing
Old Nov 2, 2006 | 02:29 PM
decipha's Avatar
Default wheel bearing
any one ever replaced the wheel bearings in the rear end? The rear end is making a grinding noise and i can't isolate it, however, the noise does seem to silence a little when i apply the handbrake, its been making this noise since the car got a little wet from katrina, i already replaced the rear end fluid and replaced the rear brake drums and shoes, the noise still persists, if anyone knows what may be the culprit please enlighten me.. thanks
Old Nov 2, 2006 | 02:30 PM
decipha's Avatar
Default RE: wheel bearing
i didn't quite mean to use the word grinding, its more of a 'friction' type nosie
Old Nov 2, 2006 | 02:41 PM
decipha's Avatar
so nobody knows how to replace one?? a quick run down with the tools needed will suffice
Old Nov 2, 2006 | 06:25 PM
MadMikeZ28's Avatar
You have to giva a little more time than eleven minutes for an answer. So I will stretch this out some.
To start, Depends on what rear end you have.
Old Nov 2, 2006 | 06:37 PM
You need to remove the axles and take them to a shop to get new bearings pressed on.
Old Nov 2, 2006 | 11:54 PM
v8chvyguy's Avatar
What rear end is it? If it's a c clip axle there is no press work required, but, you need an axle bearing remover tool and a slide hammer. The new one insalls with a seal driver and hammer.
Old Nov 3, 2006 | 03:15 AM
shnormo's Avatar
EXACTLY!
ORIGINAL: v8chvyguy
redemption91
Oct 30, 2010 09:22 AM
REN
May 20, 2010 04:02 PM
The Banks
Aug 3, 2007 08:47 AM
Saint_Ali
Jul 20, 2006 04:15 AM
Saint_Ali
Jul 18, 2006 01:14 PM
