front wheel bearing
Old Jul 8, 2006 | 01:37 AM
Saint_Ali's Avatar
Default front wheel bearing
does anyone know a good place that can install a front wheel bearing assembly on a 93 z28, i know we dont all live in the same place so maybe someone can reccomend a national place
Old Jul 18, 2006 | 01:14 PM
Default RE: front wheel bearing
That is a vey simple job and most repair shops should be able to handle it. The hub and bearing come as an assembly, which is held on to the steering knucke by 4 bolts.
1) remove front wheel
2) unbolt caliper & place out of the way, do not disconnect hose.
3) remove brake rotor (disk)
4) disconnect antilock brake electrical conector (if you have antilock brakes)
5) unbolt hub assembly & replace (make sure you get the right one, standard or antilock brakes)
redemption91
Oct 30, 2010 09:22 AM
REN
May 20, 2010 04:02 PM
The Banks
Aug 3, 2007 08:47 AM
decipha
Apr 13, 2007 02:01 PM
decipha
Nov 3, 2006 03:15 AM
