Project Bone Maro 2000 Z28
Old 06-20-2011, 01:04 PM
Massey's Avatar
The radio cutting out only when really hot may not be the BCM. If the amp in the back of the radio gets too hot the radio will shut itself down to prevent its burning up. When the radio does cut out do you lose the power windows too? If not then it is just the radio but if you do then it is the BCM again.
Massey
  #132
Old 06-20-2011, 01:36 PM
Massey's Avatar
I know you would love to fish the BCM out of the hole again. I would check over the relay posts once again.
Massey
  #133
Old 06-23-2011, 11:40 PM
Massey's Avatar
If your rear hops under acceleration that is usually due to worn bushings and or a broken trans mount. I would check that out too.
Massey
  #134
Old 06-24-2011, 01:42 PM
Massey's Avatar
The rear suspension is the weak link in this design. It is a good design but they used poor materials were used.
Massey
  #135
Old 06-28-2011, 10:21 PM
vanquishfist's Avatar
Those look very nice! I don't know why I've never seen those on ebay. I search "camaro headlights" and they're not in the list. Then I search "camaro black depo" and there they are, with the word headlights in the description...
That's also one of the plans for my car, I'm leaning towards the style like Massey's, but the ones you bought are very tempting as well. Could we see a shot of them in the daylight?
BTW, I can't remember if you mentioned it before, but how many miles are on your car?
  #136
Old 06-29-2011, 08:01 PM
Psycho's Avatar
Awesome, sounds like you are starting to actually enjoy your car.
  #137
Old 07-01-2011, 08:47 PM
Thanks for posting the pic. The headlights look very nice, much better than those yellow things on there before. The car really looks in good shape, it's a shame all the mechanical problems you've run into.
  #138
Old 07-02-2011, 07:22 AM
Psycho's Avatar
You can buy a complete crate engine for the price you quoted for rebuilding the bottom end. Actually that might not be a bad idea. Your car would not be down for nearly as long and you would be assured of no screw ups on the rebuild.
I think I would stay with the same displacement, as there are issues with LS3 engines(and accessories) when swapping out 5.7s
check this site out.
Performance Engines & Engine Parts from Turn Key Engine Supply
  #139
Old 07-05-2011, 11:14 AM
Good to hear you are making some progress. I agree with Psycho that you should get a new crate engine. You can do a lot with just that engine, with no headaches of a different engine swap.
  #140
Old 07-05-2011, 02:22 PM
Cheeks's Avatar
August 2011 ROTM
we just picked up a dropout 5.3 motor for 350 bucks, you don't need to spend ALL of that money at once, a 5.3 with heads and cam will run about 1000-1200 bucks and give you plenty of horsepower to play with for now
Quick Reply: Project Bone Maro 2000 Z28
