Mild surging during acceleration & cruise
Old 12-22-2012, 07:53 PM
heres a link to what it says for a 51, http://www.mifbody.com/DTCs/DTC%2051.jpg
also heres links to the rest of em. LS1TECH - View Single Post - OBD1 DTC Codes & Troubleshooting
if 51 keeps coming up i would say pick up a tested ecm, run between 120 and 200 bucks. make sure you get the right one for your trans, make note of any numbers on the ecm.
Old 12-23-2012, 10:03 AM
rockinjohnny's Avatar
Yes, I did disconnect the battery before removing the ECM. Will disconnecting the battery alone reset the ECM and clear the error codes?
Old 12-23-2012, 10:10 AM
you can insure a ecm reset by touching the battery cables together (pos and neg) for a couple minutes, while they are "not" connected to the battery of course. make sure to unhook any aftermarket stereo equipment or electronics
Old 12-23-2012, 12:09 PM
Yes, I did disconnect the battery before removing the ECM. Is disconnecting the battery sufficient to reset the ECM and clear the error codes? Or are there additional steps necessary to clear the error codes?
Old 12-23-2012, 12:16 PM
it should reset,,, if you question if it did you can insure a ecm reset by touching the battery cables together (pos and neg) for a couple minutes, while they are "not" connected to the battery of course. make sure to unhook any aftermarket stereo equipment or electronics, this also resets any sensors memory.
__________________
Old 12-23-2012, 12:20 PM
Woops! didn't realize the thread became a 2 pager. Sorry for the duplicate post.
Old 12-24-2012, 06:56 PM
Chaotic94's Avatar
September 2011 ROTM
My car did this for a while and it didn't throw codes. I changed the spark plugs and that fixed it.
Old 12-25-2012, 06:36 AM
Everett#2390's Avatar
Good info given here from Craby.
My suggestions are:
1. Change fuel filter, it has been sitting for a long time.
2. Run a can of injector cleaner at the next tank fill.
3. As said, disconnecting power to the ECM resets it - drive the car for it to relearn.
My '88 Dually OBD1 sputters, surges, anything with an S, until I drive it to operating temp and give it WOT. The more its driven, the better it runs.
When ECM is put into diagnostic mode, first DTC should be 12 - ECM is communicating and good. You can short OBD 1 connector pins A to B and count the CEL flashes for DTC's, ie, flash, space, flash, flash, space, space, 12, 12, then the rest of the DTC's given by flashes.
And yes, a spark plug change, new air filter, make a world of difference.
LETSROC
82-92 V8 Tech
14
05-10-2013 06:17 AM
RamzaFreak20
02-21-2012 08:34 AM
disipiot
06-03-2011 03:03 PM
tipdrip215
03-25-2008 03:42 PM
gtodave05
82-92 V8 Tech
12-03-2006 11:55 PM
Quick Reply: Mild surging during acceleration & cruise
