engine surging
Old Nov 26, 2006 | 06:14 PM
gtodave05's Avatar
Default engine surging
Hey all new to this forum. I have a 91 rs 305 with 150,000 miles on her. My q is: when i turn the heater or defrost on, the engine surges like when i'm stopped at a light, if i turn the heater off motor idles fine!! Has anyone had this prob b4 and what can i do to fix it? Thx
Old Nov 26, 2006 | 08:35 PM
shnormo's Avatar
Default RE: engine surging
It sounds like you have a vaccuum leak.
Old Nov 28, 2006 | 02:32 PM
Camaro_Kid's Avatar
I have a kind of similar problem, when ever im stopped at a light I notice my engine sounds sort of bogged down, but when I turn off my heater it idles fine.
Old Nov 28, 2006 | 03:51 PM
FlufyTiger's Avatar
Probably a vacuum canister leak, or a line running to or from it. There's a canister in the vac system meant to retain vacuum so the HVAC system won't default to defogger if you snap the throttle, since the ducts are vacuum controlled.
Old Nov 28, 2006 | 09:18 PM
gtodave05's Avatar
i hear the clutch on the compressor alway kickin on and off too is that maybe the prob?
Old Nov 28, 2006 | 11:28 PM
FlufyTiger's Avatar
If it's doing it more than ussual, it's probably low on refrigerant, and it's not likely the cause, but it's possible.
Old Dec 1, 2006 | 02:23 AM
Dan88IROC Z's Avatar
It's typical to feel a little 'blip' in power when the compressor is turning on and off.
Is it enough to make the nose of the car dive?
Old Dec 1, 2006 | 03:49 AM
XTC42's Avatar
HELLO EVERYBODY IN CAMARO CYBERLAND,I AM A NEW MEMBER TONIGHT.I WILL SOON BE UNLEASHING THE FRANKSTEIN OF CAMAROS,AND THE PICS TO PROVE IT.THE CAR HAS TAKEN 12 YRS TO BUILD ON AND OFF,AND SHOULD BE AT THE GOODGUYS SPRING GETOGTHER HERE IN NOR-CAL....OK ITS A BASE 1987 IROCZ,98 TRANS-AM INTERIOR,89 CORVETTE REAR FRAME AND REAR END AND VIPER TIRES/WHEELS.THE MOTOR IS 450 HP ALL MODIFIED CHROME AND MORE......
Old Dec 1, 2006 | 03:56 AM
FlufyTiger's Avatar
Why are you posting on this thread? And why all caps. Make a new thread if you wanna announce your car, don't try to hijack this one.
Old Dec 3, 2006 | 11:55 PM
nickdotcom's Avatar
CAPS LOCK! FAST FORWARD TO COOL!!!!!
only 450 horse? thats weak as hell
67SuperSport
67-69 V8 Tech
Jul 20, 2015 11:41 PM
LETSROC
82-92 V8 Tech
14
May 10, 2013 06:17 AM
disipiot
Jun 3, 2011 03:03 PM
96LT1
Jul 8, 2010 08:51 AM
wils5150
Jun 23, 2010 04:18 PM
