Fuel pump issue
I've been having issues with my racetronix fuel pump that I installed with my swap. What happens is that I turn the key and the pump doesn't prime. I originally thought it was the relay, so I replaced that and it sort of fixed the issue, but when I took it for the first test drive the pump cut out and left me stranded. I believe this has something to do with the new BCM I put in (because mine was going bad). Note the cars VATS is bypassed with a resistor, so could it be a VATS issue.Does anyone have an idea of what my problem is? I have a bunch of voltage readings if someone could use them to identify the problem.
The security light and air bag light recently came on. I think the security light came on after I changed the bcm but i am not 100% sure. I dont think VATS is in the bcm though.
johnson3034
05-25-2007 09:35 PM
