catalytic converter prob
i have a 1996 camaro 3.8 and my cat. converter makes some wierd noises along with rattling when i put the car into gear so im gonna definitely get a new one and what would you guys recommend meto do, gosummitracing.com and order a direct fit magnaflow cat. converter which will require no welding or cutting of any sort so i can install it myselfand also get the magnaflow cat-back system i've been wanting for 4evr which will add up to about $660 (which isn't a prob) or would i be better off going to like car-x r something and just have them put on all new exhaust
RE: catalytic converter prob
my bad, so my question is would the manaflow be worth it as far as performance and sound goes? taking into consideration i only have a v6... or would it be a waste spending that kind of money on exhaust for a v6?
It wouldn't necessarily be a waste of time. Not sure how much preformance you will gain out of the magnaflow with the v-6, but if you get the cat and the stainless exhaust,you may get a few extra horses, an exhaust which could outlast the car/no rust,and a nicer sound.
Although I always do get a good chuckle out of people with 4 and 6 bangers who have exhausts (more so those with 4 bangers). LOL
I recently replaced my catalytic converter with a direct fit. Make sure you order the correct one. There was no way of distinguishing the two models offered, and luck have it, I ordered the wrong one. The inlet pipes were too short which made the crossover touch the oil pan. After that problem sorted out, installation was a breeze, given you have access to a lift. I also purchased a flowmaster cat back system, and it sounds great throughout the low to mid RPM range. Higher RPMs will let some people know you're running a V6, but that doesn't bother me any. It definately doesn't have the bumblebee sound.
