Catalytic Converter
Old Aug 29, 2010 | 01:00 PM
Kendagenius's Avatar
Default Catalytic Converter
Will a intake manifold gasket leak cause my catalytic converter to fail? I was told i need my gasket replaced... Catalytic converter failed on me last night... Need to figure out what caused it to fail so my new one wont fail either!!! Help please
Old Aug 29, 2010 | 02:01 PM
osduck5's Avatar
I don't know but I have heard it will cause it to fail also. However, the intake manifold leak would be a priority over the cat in my book.
Old Aug 29, 2010 | 02:08 PM
Chaotic94's Avatar
September 2011 ROTM
Get that gasket fixed asap! Then and ONLY then do you replace the catalytic converter.
Old Aug 29, 2010 | 02:47 PM
In what way did your Cat fail?
Old Aug 29, 2010 | 05:39 PM
98 v6 camaro
Old Aug 29, 2010 | 05:51 PM
1augapfel's Avatar
When a cat "fails" it means that it no longer able to cause the chemical reactions that 1) reduce oxides of Nitrogen to elemental N and O2 and 2) oxidize/burn up the unburned fuel that has left the exhaust manifolds and entered the exhaust system.
The cat can be contaminated. This happens if you use leaded fuel. It's called poisoning the cat. The structure is still sound but the cat is reactively inert.
The cat can be structurally damaged. This is usually caused by overheating it due to a malfuctioning injection system, a leaking injector, a bad EGR valve, etc. The cat's ceramic matrix gets so freakin' hot (1000F +) that it melts and breaks into pieces. This can cause your car to catch on fire while you're driving it but not always.
There's also physical damage from driving over something.
How did your cat fail?
Old Aug 29, 2010 | 07:13 PM
The intake leak can result in a lean mixture causing random misfires. Even though the mixture is lean the resulting misfires will dump raw fuel into the exhaust. This can cause the cat to overheat in an effort to bur off the excessive fuel, and get damaged n the process.
Old Aug 30, 2010 | 12:25 AM
not sure how it failed. i will take it to shop tomorrow to find out
B_Dubya
Jul 17, 2015 09:26 AM
skinut
Feb 21, 2010 10:37 AM
AmirGTR
Jun 8, 2009 05:26 AM
bobc04
May 5, 2008 09:15 AM
kwwrestler
Mar 16, 2008 07:37 PM
