camaro turn's but wont fire CODES INSIDE !!!!!!
#22
ok now go to the other two wire plugin, it should have a empty place for a third wire, unplug it and switch your tester to the 2k ohm setting then test between the two wires on that plugin. should be between 900 and 1200 ohms.
#24
ull need a helper on this one. set the tester to 2v ac, doesnt say but im assuming its the same wires, turn the motor over and watch the volts. should be more that .1 volts. (100mv)
CastleRockCamaro
07-05-2010 07:35 PM
mrmiller2u
82-92 V8 Tech
09-10-2009 06:48 AM
