camaro turn's but wont fire CODES INSIDE !!!!!!
ok well i think u need to get a noid light a see if the injectors are getting direction to fire. also just in case check the injector fuses in the under hood fuse box. its in a black box on the driver side wheelwell.
all fuses are good under the hood & on the side of the dash... the fact that im not getting any voltage from the camshaft semsor worries me... i just had the icm tested 3 times at advance auto and its good
24x crank sensor- .13 VAC 6.5 ohm
3x crank sensor- .73 VAC 945 ohm
camshaft sensor- 0 VAC .4 ohm
there is a plug with 5 wires that goes into the icm one looked red so i tested it and it showed 1.5 vdc.... the other two plugs only had two wires each which go to sensors... is there any way to get the computer tested??
