camaro turn's but wont fire CODES INSIDE !!!!!!
Old May 1, 2010 | 01:36 PM
ok well i think u need to get a noid light a see if the injectors are getting direction to fire. also just in case check the injector fuses in the under hood fuse box. its in a black box on the driver side wheelwell.
Old May 1, 2010 | 02:00 PM
NEW_CAMARO_OWNER's Avatar
all fuses are good under the hood & on the side of the dash... the fact that im not getting any voltage from the camshaft semsor worries me... i just had the icm tested 3 times at advance auto and its good
24x crank sensor- .13 VAC 6.5 ohm
3x crank sensor- .73 VAC 945 ohm
camshaft sensor- 0 VAC .4 ohm
Old May 1, 2010 | 02:21 PM
found this.
Size:  70.4 KBName:  dtc36for933-1.jpg
Old May 1, 2010 | 02:33 PM
i just tested for spark and NO SPARK... i tested it last time i was tinkering with the camaro (1 month ago) and it had spark
Old May 1, 2010 | 06:20 PM
are u getting 12volts to the pink wire on the icm?
Old May 1, 2010 | 07:31 PM
there is a plug with 5 wires that goes into the icm one looked red so i tested it and it showed 1.5 vdc.... the other two plugs only had two wires each which go to sensors... is there any way to get the computer tested??
Old May 1, 2010 | 08:12 PM
the pink wire is the power wire. red is the 3x referance low.
Old May 1, 2010 | 09:48 PM
there is no pink wire theres like 2 white,1black,1red, and some other color
Old May 1, 2010 | 10:34 PM
BasicConcepts's Avatar
Technical User
have you never seen this color b4 lol
Old May 1, 2010 | 10:36 PM
  #20
pink wire should be on one of the plugs with two wires on it.
