Camaro shuts off at around 210 degrees
Old Oct 2, 2011 | 10:22 AM
Senshi09's Avatar
Originally Posted by Mbueno19
But there is a weird noise coming from the fuel pump when the care shut off. The fuel pump makes a low subtle sound but when i feel the car shutting off, it starts making irregular sounds and then the car shuts off. Once it shuts off, it doesn't turn on at all until the temperature goes down.
I will try to check the wiring as well, it could be a wiring problem.
But for now, the car hasn't shut off yet. Its done it about three times already.
Fuel pump.. thats a good piece of info to look into. That can be your problem in my eyes. Sounds to me like
1. Something is draining the power from the fuel pump
OR
2. the fuel pump is overheating and shutting down.
Circle fuel pump in your mind, that seems to be the cause of this whole schpliel to me. I could be way off base but it wouldn't hurt to look into it. Find out exactly what is going on when this all happens.. does the driver fan kick on then immediately after the car dies.. or does it kick on, then the big fan kicks on, causing the car to immediately die?
Also the driver side fan, did you install it or did it come with it from the factory already installed? That could be whats drawing all the power, causing the big fan to barely kick on and killing the fuel pump at the same time.
Old Oct 2, 2011 | 10:42 AM
Mbueno19's Avatar
I believe the driver side fan is from factory. And i think its probably the fuel pump overheating, my dad told me the same thing. That could be a possible reason. As for the battery not taking it that might not be a possibility as i got the cars electrical system checked and everything was good. And there is no check engine light that turns on and when it does, the codes that come out are: Knock sensor signal1&2 short/low; catalyst efficiency low bank 1. I did get a suggestion of bad wiring, or bad computer. Maybe thats something thats causing it but i don't think so, i could be wrong though.
Old Oct 2, 2011 | 11:38 AM
Senshi09's Avatar
youre getting codes for a short.. that signals wiring. Cat efficiency would be related to the exhaust, which is effected by the fuel, which is controlled by the computer i do believe. So your problem might not be the fuel pump (not intentionally anyway-will still need replaced most likely due to it overworking so much causing it to burn out) but the computer. If I am wrong, then somebody PLEASE correct me.
Its drawing more power then it should to power the fan, which in-turn takes the power away from the fuel pump, causing that to work even harder which makes it overheat and shut down.
Its newtons law, for every action there is a equal and opposite reaction.
The action is the fan being told to kick on, but with more power then normal.
The reaction to that is the extra amount of power is being taken from the fuel pump.
If the fan does NOT kick on, the fuel pump will be fine, but the motor will overheat.
Funny how things work out. Damned if you do and damned if you don't at this point..
Question now is.. do more research on the subject or change the computer/fuel pump and see what happens?
Old Oct 3, 2011 | 11:04 AM
Mbueno19's Avatar
Yeah thats true. Thank you for you help. And lets see what happens then i will have the computer checked out and everything else. Hopefully it isn't something to bad.
Edd2001
Jul 24, 2021 01:59 PM
professionaldriver
Feb 17, 2012 11:36 AM
Bacamaross
Aug 27, 2009 02:31 AM
nacx
Jan 12, 2009 05:09 PM
ahittz24
82-92 V8 Tech
May 8, 2007 01:11 AM
