67 BB running 170 degrees
Old Feb 16, 2012 | 01:06 PM
professionaldriver's Avatar
Default 67 BB running 170 degrees
New to forum... just purchased 67 RS 396 auto trans car to restore, the drivetrain is complete, working on body and interior. The engine is a later 454... Need advice on engine running at 170 degrees at idle with 160 degree thermastat in it, non clutch flex fan, no shroud. The engine area is not hot, the valve covers are only warm. Should I change to a 180 thermastat, to bring the temp up to a hotter operating temp??
Thanks
Old Feb 16, 2012 | 09:05 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
you could run a little hotter thermostat but thats a fine operating temp to run on a older carberated motor. you want to stay away from anything above 190
Old Feb 16, 2012 | 09:13 PM
Wow, you have the opposite problem of what some big block, and even some small block guys have. You must have a good cooling system.
Yes, I'd slap in a 180 stat and see what happens. A running temp of 170 is too cold, 180 is just right. 190 isn't going to hurt, but that's as hot as I'd want my engine to go.
Old Feb 17, 2012 | 11:36 AM
Default cool running bb
thanks guys, that's kind of what I figured, just looking for some input.
Mbueno19
Oct 3, 2011 11:04 AM
iambatman
67-69 V8 Tech
Dec 24, 2010 03:33 PM
ScottD
Mar 19, 2010 01:30 PM
ahittz24
82-92 V8 Tech
May 8, 2007 01:11 AM
