LT1/LT4 Tech 1993-1997
93 camaro starts and shuts off.
Old Aug 26, 2009 | 04:42 PM
Bacamaross's Avatar
Default 93 camaro starts and shuts off.
My 93 camaro starts and shuts right off the fuel pump stays running and its getting spark the injectors dont seem to be palseing i tryed hooking into the computer with scan tool and all it says error lost communication.
So im guessing i need a computer or could it be somthing else?
I did checked all the power and ground wires also.
Old Aug 27, 2009 | 02:27 AM
should be a couple of fuses in the power box (black box) under the hood for the injectors. one for one side of the motors injectors and one for the other side. check to see if there blown. if not then check to see if there gitting power at the fuse connections.
Old Aug 27, 2009 | 02:31 AM
the scanner i have i have to set it for a 92 to get it to read. called and the tech had me check for a 94 and then the 92. check your fuel pressure. the pump may be running but not getting pressure to the system.
Edd2001
Jul 24, 2021 01:59 PM
lynnyleigh
Jul 26, 2011 11:55 AM
ic1187
Jun 1, 2011 12:09 AM
strictly07
Jul 18, 2010 08:47 PM
nacx
Jan 12, 2009 05:09 PM
