Bad rear wheel bearing
Well over the past few weeks I've been trying to find out why I've been getting such horrible mileage.. 11.2 to be exact. Well I took it to a shop today to have then thoroughly look at it to find out y and they said they can't find anything wrong with it.. The only thing thy found was a bad rear wheel bearing its starting to seize up. Now could that have anything to do with my mileage and possible making my car run hotter on the highway than usual because of friction?
I would guess if theres enough drag on the engine from the failing wheel bearing, then it would act like a brake being applied while trying to drive the car which would both lower your mileage and make the engine work harder inturn causing it to run hotter. So yes, the theory is plausible in my opinion.
There would have to a lot of drag to lower the gas mileage that much though. Most common causes of poor mileage is the ignition system needing a tune up, O2 sensors needing a tune up or excessive sludge build up.
Well I've already changed the plugs and wires with the original ac delcos and I did change the bank 1 o2 sensor cause that code did show up but I didn't change the bank 2 but should I even though a code didn't pop up for it? How do I get rid of the sludge? A engine flush?
If a wheel bearing (that's constantly doused in oil, btw) has so much friction that it can cause drag, (simulating brakes), it's going to chew itself apart in no time flat. I'm not buying into that theory.
test evap system, https://camaroforums.com/forum/lt1-l...-system-51219/ test fuel pressure, 4th Gen LT1 F-body Tech Articles if the fuel injectors have never been cleaned then send or take to injector shop and have them cleaned and flow tested. test intake air temp sensor, coolant temp sensor, 4th Gen LT1 F-body Tech Articles
auto
02-26-2012 06:52 PM
