Another z28 wont start issue.
#55
I come to this thread with great news..
I swapped the opti and on the first try didnt line it up properly. It's very easy to miss align the one that is correct to the dowel pin on the cam. I lined it up right and it fired up.
when it wasnt lined up i was getting no start.. I checked if i was getting spark at the coil and it was ticking like it should. but when i cranked it it just wouldnt run, and after the key was out of the start position it would kick a couple times before it shut off.
#56
Ok, it runs nice, but at low rpm it rumbles a bit, brought it to a good mechanic to see if he could help me see if it wasnt on all cylinders, and he thinks it isnt either.. Idk how to check which one isnt. but there is no code, so i suspect its a plug wire not all the way on or something.
