97 Electric issue
Old Feb 27, 2010 | 01:46 PM
midrange's Avatar
Exclamation 97 Electric issue
Hi there, and i hope this is in the right section.
I have a 97 V6 Camaro. I noticed it has an electric issue. My radio will flash on and off. SOmetimes it will shut off, then when i start driving it will turn on again. I then noticed that when it shuts off, i can not control my windows or mirrors. Its irregular and does it whenever.
I googled the issue and found that others have had the exact same issue, but there was no solution.
Example - http://answers.yahoo.com/question/in...7152756AA5nW2C
I checked for frayed wires in the door jam, but those wires were all good.
Anyone?
Thank you.
Old Feb 27, 2010 | 02:41 PM
midrange's Avatar
Well after some constant searching, I have found that the BCM (Body COntrol Module) would be the culprit of this issue.
Can someone tell me where the BCM is?
Old Feb 27, 2010 | 03:45 PM
midrange's Avatar
OK. Sorry for the newb questions, but its all figured out now.
Seeing this is a common problem for the 97, I will give the details.
The BCM its self wasn't the issue, but it was one of the plug harnesses going into it. There are 3 plugs on the BCM, a blue, black and tiel. The black harness is what has all the power supply for the BCM. The red wire on that plug gets lose and you need to adjust the pin in the plug. Once you do that, it will not cause any more issues.
FYI, the BCM is located behind the glove box under the kick panel. Very easy to get to, but not easy to work with.
Old Feb 28, 2010 | 09:46 PM
Cork's Avatar
Good job searching and finding the solution yourself. Thanks for posting the summary.
Old Feb 28, 2010 | 10:23 PM
x2^^^ just think of the money u saved using the forum. lol the net pays off once in a while.
anthony7888
70-81 V8 Tech
Aug 22, 2011 03:39 AM
typeomang
Feb 25, 2011 01:40 PM
1981TypeLt
Dec 2, 2008 08:34 PM
