key wont turn in drivers side door
Old Jan 9, 2010 | 07:48 PM
tipdrip215's Avatar
Default key wont turn in drivers side door
i cant unlock my driver side door with a key, when i put the key in the slot it wont even turn. what is the problem?
Old Jan 9, 2010 | 07:53 PM
imalixZ28's Avatar
where do you live? if in a really cold place did you try shooting lock de-icer in there? any damage to the key or lock that's visible?
could some how maybe be corrosion inside the lock? wd40?
Old Jan 9, 2010 | 07:58 PM
tipdrip215's Avatar
i live in NC, not that cold usually. no visible damage in the lock, and everywhere else you can use that key (glove box, both t-tops, trunk, passenger side door) it works fine.
Old Jan 9, 2010 | 08:15 PM
torque_is_good's Avatar
I don't even know if you can get it any more but graphite works wonders. I haven't bought any for years but you used to be able to get a little squeeze bottle of it at the parts store, squeeze a little into the key hole and the lock turns free and easy.
I just did a quick Yahoo search. I guess you can still get it. If it's on-line then hopefully the auto parts stores still carry it. I think I'll get myself a bottle to have. it's even good for house locks, boat locks etc etc
http://www.autobarn.net/chle-4.html
Old Jan 9, 2010 | 08:18 PM
tipdrip215's Avatar
ill look into that, thanks. are you sure its not a broken part though?
Old Jan 10, 2010 | 02:19 AM
GMDCAMARO's Avatar
Have you tried wiggling it, in and out, while to try to turn it?
Old Jan 10, 2010 | 09:57 AM
pitbull12887's Avatar
Mine does the same thing with the passenger door and i live in nc lol. Also my cars security stays on and my unlock on my keyless wont work so if i open it with my key the alarm goes off every time. Therefor usually leaving my car unlocked : /
Old Jan 10, 2010 | 12:27 PM
Your latching or locking mechanism could be rusty, stiff from old grease, or both. Get a can of PB Blaster, lower the window down, and reach the spray hose between the rear window opening of the door and aim at the latch, up high so it will run down. You can also spray the latch from the outside of the door. Then spray between the glass and the outer part of the door trying to get the lock and linkage lubed. Spray a little into the key lock and work the key in and out and try to turn it to loosen everything up.
Old Jan 18, 2010 | 02:12 PM
tipdrip215's Avatar
sorry for the slightly late reply, but there are instructions in the owners manual on how to disable the alarm. i did mine like that. if i remember correctly, i think it involves putting the ignition in ACC, pulling some fuse and hitting the unlock button to change the setting.
Old Jan 18, 2010 | 02:22 PM
has the lock been messed up from the before u got the car or did it start recently? if so was there work on the widow or window motor or the door in any way. linkage from lock to key mechanism could be jammed.
