-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   4th Gen: How-to and FAQ - Have an issue? Start Here (https://camaroforums.com/forum/93-02-general-41/4th-gen-how-faq-have-issue-start-here-38462/)
SpecterGT260 May 10, 2009 07:49 PM
FAQ and Common Problems
4th Gen common Q & A
4th Gen VIN Decoder
T56 Transmission, Description & Operation
4L60e failure to upshift @ WOT
How - To Articles
How To: Convertible top replacement (Long!)
How to swap out a 4L60E for a T56
How to change 4th gen window motor
craby Aug 4, 2011 09:00 AM
More how to help
1 how to bleed air from lt1 https://camaroforums.com/forum/lt1-l...tem-lt1-66742/
2. lt1 turns over but will not start https://camaroforums.com/forum/lt1-l...37/#post579761
2.5 3.4 will turn over but not start https://camaroforums.com/forum/93-02...18/#post618955
3 How to unlock a THEFTLOCK or DELCO-LOC II audio system How to unlock a THEFTLOCK or DELCO-LOC II audio system
4 adjust/shim starter https://camaroforums.com/forum/gener...himming-20175/
5 test engine fans; https://camaroforums.com/forum/4th-g...ne-fans-54192/
6 measure pushrod length; https://camaroforums.com/forum/4th-g...-length-51829/
7 test maf; https://camaroforums.com/forum/4th-g...ing-maf-63856/
8 test the evap system https://camaroforums.com/forum/lt1-l...-system-51219/
9 93-97 fuel pump change with hatch mod; https://camaroforums.com/forum/4th-g...-method-63702/
10 changing fog light bulbs in the 93-97 http://www.bfranker.badz28.com/fbody/fogs.htm
11 repair bcm; https://camaroforums.com/forum/4th-g...-repair-52062/
11.5 more bcm info http://www.camarozone.com/forum/f18/...io-locks-6733/
12 changing auto trans; https://camaroforums.com/forum/4th-g...mission-52327/
12.5 removing t56 trans https://camaroforums.com/forum/lt1-l...val-how-70184/
13 replace convertible top; https://camaroforums.com/forum/4th-g...nt-long-37312/
14 replace window motor; https://camaroforums.com/forum/4th-g...92/#post567086
14.5 adjust door window http://shbox.com/1/adj_window.html
15 window wiring mod AutoTrix :: Passenger Window Fix Kit
15.5 How to replace plastic door handle rod retainer https://camaroforums.com/forum/lt1-l...etainer-78615/
17 fix t-top leak; https://camaroforums.com/forum/4th-g...eak-fix-63855/
18 rear-shock-replacement-4th-gen-convertible https://camaroforums.com/forum/4th-g...91/#post570077
19 windshield wiper diagnostic and removal https://camaroforums.com/forum/4th-g...rmation-66130/
20 how to change pinion seal
https://camaroforums.com/forum/93-02...35/#post610426
https://camaroforums.com/forum/93-02...leaking-66094/
21 how to change transmission mount https://camaroforums.com/forum/93-02...85/#post615714
22 replacing 1997-02 gauge cluster bulbs - many pictures https://camaroforums.com/forum/4th-g...ur-dash-67093/
23 how to remove opti http://www.lt1engines.com/tech/93-97...emove-replace/
24 make own tool for removing opti cap https://camaroforums.com/forum/lt1-l...41/#post614528
25 test and by pass vats
http://shbox.com/1/pass_key.html
http://shbox.com/1/4th_gen_tech2.html#pass_key
http://shbox.com/1/vats_bypass.jpg
https://camaroforums.com/forum/techn...-delete-63327/
https://camaroforums.com/forum/93-02...rt-vats-69934/
25.5 vats bypass module http://performanceparts.com/part/Painless/64024
26 fuel injection size calculator http://www.fuelinjectorconnection.co...tor/index.html
27 How to adjust throttle postion sensor https://camaroforums.com/forum/93-02...-sensor-70605/
28 rear disk brake info https://camaroforums.com/forum/lt1-l...56/#post639140
28.5 LS1 Front Brake Swap LS1 Front Brake Swap
29 install aftermarket steering wheel https://camaroforums.com/forum/93-02...4th-gen-72056/
30 Turn Signal Switch Replacement
, Turn Signal Switch Replacement
31 Header Install https://camaroforums.com/forum/lt1-l...4th-gen-58225/
32 replace your auto shift knob https://camaroforums.com/forum/93-02...-1995-a-72666/
33 VSS info and tests https://camaroforums.com/forum/lt1-l...44/#post655676
34 How to remove radiator Lt1 https://camaroforums.com/forum/lt1-l...15/#post662527
35 heater core removal https://camaroforums.com/forum/lt1-l...23/#post662550
36 remove upper and lower intake 3.4 https://camaroforums.com/forum/93-02...99/#post665301
36.5 how to change 3.8 intake gaskets https://camaroforums.com/forum/93-02...01/#post702716
37 replace valve cover gasket 3.4 https://camaroforums.com/forum/93-02...6-3-4-a-69469/
38. remove ignition switch 98-02 https://camaroforums.com/forum/93-02...46/#post684720
38.5 remove ignition switch 93-97
39. how to swap v6 to carb'd v8 https://camaroforums.com/forum/93-02...4-5-7-a-45720/
40. test pluged cat https://camaroforums.com/forum/93-02...28/#post687788
41. Scan9495: Free OBD1 PC scan app for 94/95 LT1 https://camaroforums.com/forum/compu...-95-lt1-77363/
42. Rear wheel bearing R&R https://camaroforums.com/forum/93-02...98/#post707158
43. replace dash lightbulbs https://camaroforums.com/forum/93-02...ur-dash-67093/
44. led dash light swap info https://camaroforums.com/forum/93-02...A%2A%2A-59143/
45.
46 cylinder compression test https://camaroforums.com/forum/lt1-l...on-test-80391/
47. Rear Hatch Release Fix 2 (1999 and Newer) http://installuniversity.com/install...ease_fix_2.htm
48. lapping/freshing up your valve seats https://camaroforums.com/forum/93-02...26/#post723326
49. restore headlight lens https://camaroforums.com/forum/93-02...98-02-a-82183/
