redline
Old Nov 4, 2007 | 04:57 PM
z28daytona's Avatar
Default redline
Just got my camaro the oter day and I have an aftermarket tach installed because the stock one doesnt work. Just wondering what the redline should be set at, its set at about 5200 but in drive it has gone to about 6 before it changes gears.
Old Nov 4, 2007 | 06:38 PM
MadMikeZ28's Avatar
Default RE: redline
Well if you look over the years on some the max HP was around 4800rpm. As you go over the max your HP will drop. But going into 6k is going into too much for a stock small block. Its like when people drive with a slipping tranny and all of a sudden the rods are sticking out of the oil pan.
Old Nov 4, 2007 | 07:21 PM
1990CamaroRS's Avatar
Fancy Sparkle
Default RE: redline
mine redlines at 7000, but i'm not anywhere near stock
Old Nov 4, 2007 | 08:31 PM
z28daytona's Avatar
Default RE: redline
I have no idea what the guy who owned the car before me did to the engine. All I know is its a 350 and only has about 10k miles on it.
Old Nov 6, 2007 | 10:05 PM
Fancy Sparkle
Default RE: redline
ya, just a "mild" cam, a little head work, some beefing of the bottom end. hey, can't argue with beating most Civics in redline though
Old Nov 6, 2007 | 11:48 PM
Dougs1990rs's Avatar
Default RE: redline
i've had mine past 7000 and it still want's to go more. just like 1990CamaroRs mild cam head work and 1.6 rocker's.but my buddy ha sme bet 8000+ in his 327 with 6 inch rod's and steel crank and spiral lock's
mab6680
Aug 27, 2011 09:42 AM
rockin85
Aug 10, 2007 08:03 PM
95s/cZ28
Sep 28, 2006 03:04 AM
camarohelp
82-92 V8 Tech
Jul 14, 2006 08:29 PM
