keys
Old Apr 8, 2010 | 08:30 PM
87rsmaro's Avatar
Default keys
i just got a 87 rs but the kid i got it from lost the key an it's a chipped one but i got a colum out of a 86 iroc with no chipped key if i swapp the colums outs will it be ok? thanks
Old Apr 8, 2010 | 09:40 PM
80ZJoe's Avatar
July 2010 ROTM
just try swapping the ignition instead of the whole column, should work though.
Joe
Old Apr 8, 2010 | 10:38 PM
You need the chip to tell the VATS module that you have the proper key. By replacing the lock with one that does not read the chip, the VATS module will not signal the ECM that all is OK, and the ECM will not allow the starter to engage and shut off the fuel. However you can bypass the chip by strapping a proper value resistor across the leads going from the ignition lock to the VATS module.
Old Apr 15, 2010 | 09:01 PM
1fastZ28's Avatar
Yes he is right, or u can take it to a dealor ship and get the vats code check, the have a macine that they can put into yr ignition and it will tell them the code, the code is 2-16
Gorn
May 12, 2015 10:18 PM
PedroRider310
Feb 18, 2012 05:12 PM
Knightrider03m
Mar 23, 2011 12:55 AM
smnw10
Sep 27, 2010 05:35 PM
BROCKLT1
Dec 11, 2006 12:59 PM
