Injector question
Old Jun 13, 2010 | 02:56 PM
Sewperdave's Avatar
Default Injector question
As I started to reassemble my engine, I noticed that while changing the o-rings on the injectors, 2 of the plastic sleeves crumbled away. I tried to fing them online and looked at the local parts retailers. Do I really need them?
Old Jun 13, 2010 | 06:45 PM
what plastic sleave? picture?
Old Jun 13, 2010 | 09:19 PM
Sewperdave's Avatar
It fits around the injector just above the o-ring. It was very thin and brittle and as I was wiping the injector off with a rag before installation, It broke apart. I can't post pictures. I guess I am too new.
Old Jun 13, 2010 | 10:41 PM
ah but you have 11 posts now so you should be able to. yes i beleive that piece holds the o ring in place in that spot for a reason. would be a good time to consider new injectors. you can get rebuilt ones that are pressure and flow tested for a good price from a good injector place. i have used a place called injector doctor. lol. should say on the injector what size they are. should be like 17 lbs/hour or 182cc/minute up to 24 lbs or 255cc. dont know what stock is for your yr.
Mikey.
Jan 11, 2012 09:08 PM
Devoult
Jan 17, 2011 10:36 AM
glue maker
Oct 24, 2010 09:53 PM
89 guy
Feb 28, 2007 04:22 PM
NomadicZ28
Jun 9, 2006 01:49 PM
