injector question
Old Oct 24, 2010 | 09:06 AM
glue maker's Avatar
Default injector question
will my LT1 injectors fit in my 88 IROC Z with a 305 tpi?
Old Oct 24, 2010 | 10:33 AM
blackz87's Avatar
They will fit yes, but will they work with the 305 & stock ECM & Prom..NO. You will run pig rich..
Old Oct 24, 2010 | 04:29 PM
stock 93 lt1 injectors are 24lbs, stock 88 305 injectors are 19lbs.
Old Oct 24, 2010 | 09:53 PM
If they fit, they most likely work, but there may be some idling issues. The PCM reads the O2 sensor output and adjusts injector pulse for proper mixture, and also adjusts the A/F tables to keep things happy. However, if the injector pulse is too short the PCM won't have problems controlling the injector pulse. The one thing you can't do is to mix different types and size of injectors.
Mikey.
Jan 11, 2012 09:08 PM
Devoult
Jan 17, 2011 10:36 AM
Sewperdave
82-92 V6 Tech
Jun 13, 2010 10:41 PM
89 guy
Feb 28, 2007 04:22 PM
NomadicZ28
Jun 9, 2006 01:49 PM
