LT1/LT4 Tech 1993-1997
Fuel Injector question
Old Jun 7, 2006 | 02:21 AM
NomadicZ28's Avatar
Default Fuel Injector question
Im looking to buy fuel injectors for my car but not for sure.. are they a pain to install and which ones do I need to get for my 1996 Z28? Im looking at these below.
http://www.jegs.com/webapp/wcs/store...tegoryId=11175
Also would a new flowmaster muffler give me anymore HP or make it sound any bettter? any help is appreciated!!! thank you!
Old Jun 7, 2006 | 03:53 PM
Default RE: Fuel Injector question
If you didn't do any internal mods or added forced induction, the stock injectors are just fine. Bigger injectors will not make more power, but cause you to get a PCM tune to get the right A/F ratio back. If your engine wants more fuel because of serious mods, then bigger injectors will help, but again, you will need a PCM tune to get the proper A/F ratio. One the best repalcement for a heavily modded engine are Ford 36 lb injectors, which fit right in the Chevy. To change injectors you will need to unbolt the fuel rail, and pull the whole rail and injector package away from the intake manifold. Disconnect the injectors from thr fuel rail, change them out, and put everything back using new "O" rings at the fuel rail and at the intake manifold.
Old Jun 8, 2006 | 11:53 PM
RiceHater96's Avatar
Being the fact you asked about an aftermarket muffler,I'm assuming your car is stock.You don't need bigger injectors for a stock motor,it's just a waste of money.I have upgraded injectors on my 93 z28,but I also have complete intake,exhaust,aftermarket ignition,nitrous,etc etc,so for a highly modified engine,they are great,but for a stock motor,they are a big waste of time and money
Old Jun 9, 2006 | 01:49 PM
NomadicZ28's Avatar
Ok cool! Thanks guys for the the information!
Kendagenius
Feb 5, 2017 12:23 PM
princesid84
Dec 10, 2012 09:28 PM
Mikey.
Jan 11, 2012 09:08 PM
Devoult
Jan 17, 2011 10:36 AM
johnson3034
May 25, 2007 09:35 PM
