th 350 kickdown cable.
Old May 19, 2012 | 09:19 AM
slick's camaro's Avatar
Default th 350 kickdown cable.
I want to alter my shift points a little to my liking, couple questions before I make a move.
Does the kickdown cable on a th 350 affect any pressures at any throttle position except WOT. Does it modify shift points at wot or replaces the effects of the governor
And modulator has on shift points
I would like to spread the low PT shifts. do I try a stiffer spring in 2-3 or weaker in 1-2.
Or save time and buy a shift kit. I looked at some shift kits but it doesn't specify enough
I dnt want to preload my detent and shorten the trans life if that's true.
Old May 19, 2012 | 10:11 AM
The detent cable works in conjunction with the vacuum modulator and the governor to control up and down shifts. But the detent cable doesn't control line pressure like the TV cable on the 700R4 does. If the cable isn't connected, it will cause sooner upshifts, and no downshifts. If all you're after is altering your shift points, install an adjustable vacuum modulator. A shift kit or shift improver kit will also let you firm up the 1-2-3 shifts, if chirping the tires at upshifts is what you're after.
Old May 19, 2012 | 11:29 AM
Ok shift kit it is. So the vacuum modulator does have impact on wot shift points not just the detent cable? I think I was getting the tv cable and kickdown mixed
Old May 19, 2012 | 11:30 AM
I was trying to find a flow chart at pt vs. Wot. Just was curious.
Old May 19, 2012 | 12:24 PM
This shift kit may be what you're after: TransGo Reprogramming Kit
Old May 19, 2012 | 01:34 PM
Perfect thanks 69
Old Aug 13, 2012 | 06:25 PM
Edwardgp's Avatar
You can change the weights on the governor to change your shift points.
manslaughter299
Jun 4, 2012 11:08 PM
walsh4nd
Mar 16, 2008 11:25 AM
bdam0214
67-69 V8 Tech
Oct 31, 2007 03:40 PM
bdam0214
67-69 V8 Tech
Sep 30, 2007 11:38 PM
02renegade
May 3, 2006 01:12 AM
