Kickdown cable...is it needed?
Old Apr 30, 2006 | 10:22 PM
02renegade's Avatar
Default Kickdown cable...is it needed?
I have not run a kickdown cable for years on my car and I am soon getting ym tranny (TH350) rebuilt by the local tranny guys, they say "Well...it should be there..." I know it should be there but does it NEED to be there for everything to work right inside? I could care less if it down shifts when I mash on the gas, if I want to down shift I do it myself!
Old Apr 30, 2006 | 11:53 PM
TimmyTheWop89's Avatar
Default RE: Kickdown cable...is it needed?
well if you have a full ratchet shift then who cares, but i would attach it if you have a drive or overdrive option.
Old May 1, 2006 | 01:09 AM
02renegade's Avatar
I am not sure if it matters or not, but on this tranny I have now it does not want to shift into drive, first and second are fine just no drive. Some people say thats because the kickdown cable is gone, now I have run different th350's and had no problems with drive. I think there is something wrong with this tranny I have now, not just the cable.
Old May 1, 2006 | 09:11 AM
mike86rs's Avatar
Sounds like you definately have a problem with that trans, The only thing the cable does is down shift when you stomp on the gas. It does not effect how is shifts threw the gears.
Old May 3, 2006 | 12:41 AM
1969 SS's Avatar
you WILL wreck your tranny quicker without it. nice way to burn up a torque converter from too much heat
Old May 3, 2006 | 01:12 AM
v8chvyguy's Avatar
It was engineered to have it. I would run it or swap in a 400. both my 3/4 ton 4WD's have 400's in them and my Z has the T10 4spd. I had a 350 in my old truck that had irratic shift pattern issues until I put the kick down cable on it.
slick's camaro
Aug 13, 2012 06:25 PM
manslaughter299
Jun 4, 2012 11:08 PM
walsh4nd
Mar 16, 2008 11:25 AM
bdam0214
67-69 V8 Tech
Oct 31, 2007 03:40 PM
bdam0214
67-69 V8 Tech
Sep 30, 2007 11:38 PM
