HELP! Transmission bounce and loud banging sound
Old May 31, 2012 | 01:12 AM
Paul86iroc's Avatar
Default HELP! Transmission bounce and loud banging sound
I don't know what's loose but when I drive normal in 1, 2, or 3 gear and punch it or do a hard shift it bounces and makes a loud clicking sound like its hitting something? I was told to buy a cross member bar would this fix it?
It's a stock 305 tbi 5 speed 86 iroc.
Old May 31, 2012 | 01:22 AM
You're describing a torn transmission mount. That allows the torque arm from the rearend, which is also attached to the trans, to lift rear of the trans and make it hit the tunnel.
Old May 31, 2012 | 01:26 AM
Paul86iroc's Avatar
Thanks! How do I fix it and how much?
Is it a do it yourself and how long?
Is it safe?
Old May 31, 2012 | 07:57 AM
torque_is_good's Avatar
Is it safe?
do you have a floor jack and jack stands?
do you have hand tools?
do you have a safe place in which to work?
to me, replacing a tranny mount is no big deal but to the next guy they might be intimidated so much of your questions can only be answered subjectively.
If you have a small block of wood in addition to the above tools mentioned, the ability to undo about 5 bolts, then go for it.
Total time needed including 30 minutes round trip to/from parts store and also including jacking up the car, putting away tools, washing your hands is about 90 minutes. I am not allowing time for replying to text messages or updating Facebook.
Old May 31, 2012 | 09:02 AM
Paul86iroc's Avatar
Yeah I have all that. And people to help me.thanks a lot!
I just needed a little help diagnosing the problem and finding out whether it was a serious fix or not. Thank a lot man. I'm a visual learner so I guess I could look up a couple videos on YouTube and get an idea of what to do. Also my brother and dad are very good with cars and could probobaly help me get this done in no time.
Old May 31, 2012 | 11:05 AM
Put a floor jack under the trans, and a 2x4 or 2x6 on the jack to span the pan (so you don't dent it).
Slowly jack up the trans and keep an eye on the mount. If the mount is split, the upper and lower portions will part ways.
Old May 31, 2012 | 05:40 PM
Paul86iroc's Avatar
Alright. Thanks man! Your a lot of help!
Old Aug 13, 2012 | 06:22 PM
Edwardgp's Avatar
Yes that sounds like a blown transmission mount.
grasshopper645
Aug 19, 2014 07:20 PM
SayeretDuvdevan
Apr 15, 2010 11:51 PM
BlueKitsune
Oct 14, 2008 11:02 PM
crystal27lt
Apr 5, 2007 09:49 PM
BoBoZ28
Feb 14, 2007 04:41 PM
