Loud Grinding sound
Old Feb 12, 2007 | 05:00 PM
BoBoZ28's Avatar
Default Loud Grinding sound
Hey guys i just got my 2000 Camaro in May and in Oct while driving when it shifts from 2nd to 3rd and 3rd to 4th there is a loud grinding sound under my car when I accelerate. Thecheck engine light was on and the code was for my trans cylanoids and i failed admissions, well i changed those and the grinding didnt go away but i passed admissions and the check engine light went away for 2 days and came back on and before i found the new code i put the car away for winter. When i changed the trans cylinoids there were little shavings once spring comes ill be taking it in to get fixed just wondering if anyone knows what my problem is thanks guys
Mike
Old Feb 13, 2007 | 02:40 PM
williesrepair's Avatar
Default RE: Loud Grinding sound
4L60E trans?
I'd say give me the codes you had so I can check some TSB's.
First guess is the pump failing, torque converter shot and the valve body is shot like most 4L60E trans do.
Old Feb 13, 2007 | 05:51 PM
Sounds like it is time for the tranny man. Bad things happening inside.
Old Feb 14, 2007 | 04:04 PM
BoBoZ28's Avatar
yea its a 4L60E trans
Old Feb 14, 2007 | 04:41 PM
Does it make the noise in neutral and park?
what codes did you have?
right now sounds like a planetary noise, or the thrust bearing in the convertor fubared...
Regardless, noise+4L60E=new trans/rebuilding trans (most times)
rs657f
Feb 24, 2013 05:29 PM
gonzalez_shauna
82-92 V8 Tech
Feb 19, 2009 07:16 PM
deltav
Nov 6, 2008 08:02 PM
BlueKitsune
Oct 14, 2007 09:53 PM
stitch85
82-92 V8 Tech
May 26, 2006 10:02 PM
