no idea wut happened
Old Jun 17, 2009 | 01:39 AM
  #21
the only thing left is the exciter wire to the alternator. it has to get power from the ignition switch to tell it to start working. its been so long i cant remember much on the two wire alt. im assuming the alternator has a internal voltage regulator. check in the fuse box under the hood if u have one and see if theres an igition relay. if its the same as one of the others change them and see what that does.
Old Jun 17, 2009 | 01:52 AM
  #22
mighty mike's Avatar
r u talkin about the plug that goes onto the alt with a thick red 1 and a skinny 1? the red 1 is conneted to the starter, and i cut the skinny 1. i dont have nemore relays. i took them out. except for the 1 for a/c.
Old Jun 20, 2009 | 03:42 PM
  #23
mr craby u r the man i thought that little wire was for the gauge so i cut that little wire off. so i put that little wire on the post and it worked. now does that little wire have to be on a switched 12v or can it just stay constantly on?
Old Jun 20, 2009 | 05:20 PM
  #24
it should be hooked to the ignition switch. the old igntions had alt on the switch so u would know which post the wire went to. it will run your battery down and harm the alt if u leave it hooked up.
Old Jun 20, 2009 | 07:43 PM
  #25
ok thanks u very much
quick78
Jun 3, 2011 05:33 PM
timmyz28
May 22, 2011 09:28 AM
jdubs1813
Sep 3, 2009 09:16 PM
YouLost
Jul 28, 2006 06:26 PM
