MY camaro just died :(
Old Jun 17, 2009 | 11:44 PM
littlereiter99's Avatar
Angry MY camaro just died :(
I have a 1992 camaro rs 305 stick so i was driving and then i stopped put it in neutral and then when i tried to put it back into gear it wouldn't go so i shut it off put it in gear and tried to turn it over and it lunged forward while the car turned over which means the clutch is engaged so what went wrong that i cant disengage the clutch with the pedal ??????
Old Jun 18, 2009 | 12:16 AM
low or no oil in the clutch master cylinder reservor, bad clutch master cylinder and or slave cylinder will do it. look for oil leaking around the two cylinders. master on the driver side firewall, slave is under the car driver side of the transmission. clutch linkage could have a arm that has came off. can u feel resistance when u push the clutch peddle down.
Old Jun 18, 2009 | 12:28 AM
not much
Old Jun 18, 2009 | 12:32 AM
If you pump the clutch pedal many times and quickly, does it build up pressure and then go limp again? ....no wise-cracks!
Old Jun 18, 2009 | 01:05 AM
nope if i pump it it stays the same
Old Jun 18, 2009 | 02:22 AM
outta_control_z28's Avatar
sounds like the slave went on it but could it be a throw out bearing ?
Old Jun 18, 2009 | 03:12 PM
mighty mike's Avatar
check behind the carpet inside the car where the master is bolted. see if the carpet is wet from brake fluid. is so theres ur prob and its a itch to replace.
Old Jun 21, 2009 | 03:28 PM
yup its the throw out bearing thanks outta_control and everyone else for your input
lildeezul
Aug 18, 2011 11:09 AM
jester872
Sep 6, 2009 02:20 PM
Cappi
Jul 28, 2009 04:05 PM
aleksandr
Jan 23, 2008 10:46 PM
JHL88
Jul 1, 2007 09:56 PM
