No Idea What Happened
Old Aug 27, 2009 | 10:26 PM
jdubs1813's Avatar
Default No Idea What Happened
Basically I was driving my car today and as I'm getting onto the highway, I 50 mph and all of a sudden my car stopped running right. It sounded really weird and unstable, I had no acceleration whatsoever, unless I had my foot on the gas pedal, the car would slowly sputter out and die. I honestly thought something major was wrong and that my car was going to take $$$ to repair.
Well I got to my destination, parked, popped the hood and saw nothing looked wrong underneath. There were no fluids leaking, no service engine light, no sign anything was wrong. I left the car parked for about 30 minutes, came back to it, and when I started it, nothing was wrong. It was running fine. I drove it all the way home without anything like that happening or going wrong.
Now, I'm assuming that's not the end of the problem and I expect it to be back and happen again. Any ideas on what happened or things I should check for? I'm really scared to drive it anywhere.
Old Aug 28, 2009 | 11:25 AM
blackz87's Avatar
May be a electrical problen with the alternator, battery cables for starters.
Old Aug 28, 2009 | 11:35 AM
Saint_Ali's Avatar
yeah check all your grounds and battery cables and make sure they are on tight
Old Aug 28, 2009 | 03:45 PM
ScottD's Avatar
Hate it when this kind of shi+ happens. Is your car carbed? Sounds like your choke might have done something funny.
Could just be a voodoo curse.
Old Aug 28, 2009 | 04:00 PM
jdubs1813's Avatar
alright thats what i was thinking is a ground shorting out was a possibility. forgot to mention the type of car... 1989 Camaro RS. It was a brand new (5k miles) 350 crate engine that was put in two years ago, but it's still TBI.
Old Aug 28, 2009 | 06:25 PM
microkid's Avatar
March 2011 ROTM
Technical User
i had the same problem once, figured it was my fuel pump. replaced the pump and a few weeks later had the same problem. turned out the hot wire for my fuel pump is on the battery clamp and it had gotten slightly loose so occasionally it would lose contact and stall
Old Aug 29, 2009 | 06:05 PM
jdubs1813's Avatar
alright ill have to look into the fuel pump hotwire... its on the positive terminal battery clamp u said?
Old Aug 29, 2009 | 10:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
i dont know if it should be, but mine was.
Old Aug 30, 2009 | 07:09 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
The part where you said you needed to keep the pedal maches makes me think its not so much electrical (alternator/battery) could be intermitent loose conection.. I am thinking more on the lines of a fuel system clog. When you shut down the car you turned off the pump, releasing the vacume, causing the debris to float out of the way... maybe... of course it could be something else, electrical would be easier to check.
Old Sep 3, 2009 | 09:16 PM
jdubs1813's Avatar
another thing i was thinking is if someone possibly urinated in my gas tank? i live on a college campus with my car here currently. it sits in a garage that doesn't have a garage door on it... still haven't seen a problem with it recently, but i'll post again if something changes.
quick78
Jun 3, 2011 05:33 PM
timmyz28
May 22, 2011 09:28 AM
mighty mike
Jun 20, 2009 07:43 PM
YouLost
Jul 28, 2006 06:26 PM
