blower fan switch problem
Old Feb 10, 2007 | 01:30 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default blower fan switch problem
i lost the high speed on the fan tonight, but all the other speeds are fine. does anyone know if it could be a resistor blew out, or would it more likely be the switch thats the problem
Old Feb 10, 2007 | 01:35 AM
FlufyTiger's Avatar
Default RE: blower fan switch problem
It's either the switch, or the number four wire on from the switch is bad. There wouldn't be a burnt resistor causing that, since the high setting is resistor free, and subsequently lower speeds are created by adding a resistor to the circuit per drop in speed.
Old Feb 10, 2007 | 06:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
alright, thanks. im thinking of replacing the entire climate control system on the interior because i get a lot of static hiss, especially when its off, the floor setting doesnt always go on or hisses, and now this
Old Feb 10, 2007 | 06:52 PM
ghotachevy's Avatar
i got 1 frm a 87 im partin ouy
Old Feb 11, 2007 | 03:04 AM
microkid's Avatar
March 2011 ROTM
Technical User
how much would you sell it for?
Old Feb 11, 2007 | 04:02 PM
FlufyTiger's Avatar
You sure it isn't a vacuum leak causing the hiss and the floor duct not working? It's been a while, but if I remember correctly the 3rd gen F-Bodies used vacuum controlled ducting for the climate controll. You would do well to check that out, make sure the vacuum lines are on tight and in good shape.
Old Feb 11, 2007 | 11:10 PM
MadMikeZ28's Avatar
I get that hiss once in a while. I just click the lever into the next closest position then back and foop! The blend air door closes and the hiss is gone.
Old Feb 11, 2007 | 11:40 PM
microkid's Avatar
March 2011 ROTM
Technical User
i know its a vacuum leak, but the hoses all checked out.
Old Feb 12, 2007 | 12:13 AM
cheever1804's Avatar
Okay, so it's kinda related, my switch burnt up. anyone know where can i get a new one. It really sucks not having heat in 15 degree weather.
Old Feb 13, 2007 | 12:14 AM
microkid's Avatar
March 2011 ROTM
Technical User
junkyard would be the best bet. and if that cant wait, take the switch out and make it an on/off switch
JakeYeah
Nov 9, 2012 11:14 PM
msamsonz28
Mar 16, 2009 08:09 PM
Exde
Dec 21, 2008 10:47 PM
fab
Apr 2, 2007 02:25 AM
BossMadOne
Oct 1, 2006 03:28 PM
