Electrical problem, headlight switch doesn't work
Old Apr 2, 2007 | 02:25 AM
fab's Avatar
fab
Default Electrical problem, headlight switch doesn't work
I am having an electrical issue with my 1998 v6 camaro. After installing my own radio, a connector became un loosened and some how grounded itself to another radio wire. Now I believe that I have a short or bad wire which is causing my headlight switch to constantly go out. I have replaced the switch two times already in the course of a week. I used a circuit tester to see which wire is bad. The bad wire is one of the two red wires that connects to the actual headlight switch and also a very light brown wire that connects to the headlight switch. My question is, what are my options from here? Do I have to follow this one red wire amongst miles of other wires or is there some type of short cut. Can I possibly do something with splice a good wire into the terminal of the bad one?
killer_camaro
Apr 6, 2015 07:07 AM
v64thgen
May 25, 2012 09:37 PM
Domobomb
Mar 17, 2009 03:04 PM
RSSteve
Nov 17, 2008 10:13 PM
89Frank
Aug 2, 2007 12:03 AM
