Key less entry doesn't work???
Old Nov 13, 2008 | 09:54 AM
RSSteve's Avatar
Default Key less entry doesn't work???
I have a 1996 RS Camaro and since I have owned it my keyless entry doesn't work. I replaced the battery in both remotes and still nothing. I have tried the "program procedure" in the owners manual and still nothing.... Any ideas? When I lock the doors and then unlock it with the key the horn will sound so I have to hurry and stick the key in the ignition.... I dunno??
Old Nov 16, 2008 | 10:13 PM
RSSteve's Avatar
Default RE: Key less entry doesn't work???
anyone? maybe I have to get the remotes reprogrammed at the dealership?
Old Nov 17, 2008 | 04:54 AM
stealthy95z's Avatar
what is the procedure in the manual?
just did this on my 95. had to ground the 4th pin and the 8th pin on the OBD port together. then the door locks cycled and have to hit any button on each remote one after another.
Old Nov 17, 2008 | 07:24 PM
RED96's Avatar
I have a 96 camaro that had problems with the keyless remote not working like yours . |I replaced the ignition switch aaaand everything works now. I know it sounds crazy,but that was the problem with mine. good luck.
Old Nov 17, 2008 | 10:13 PM
Camaro RS/SS's Avatar
Banned
Have you taken it to the dealer?
killer_camaro
Apr 6, 2015 07:07 AM
v64thgen
May 25, 2012 09:37 PM
camaromanv6
Aug 10, 2009 06:02 AM
Domobomb
Mar 17, 2009 03:04 PM
89Frank
Aug 2, 2007 12:03 AM
