big leak problem!
Old Mar 16, 2007 | 02:59 AM
sammyrocker5150's Avatar
Default big leak problem!
so i was replacing my thermostat on my 92 camaro, and when i started pulling out the two bolts it started leaking hardcore!! so i squeezed the hose tight and swapped the thermos. i then drove it around the block and came back with half of my antifreeze left!! i squeez the hose and it is leaking on the block, like its not creating a seal! then i put the origonal thermo on and it still leaks like its not making a seal on the block! what should i do???
Jelz28
Jul 18, 2012 06:01 PM
86iroczcamaro
Apr 19, 2012 10:21 AM
White94Z28
May 9, 2010 03:38 PM
CFallsGuy
Aug 22, 2009 12:54 PM
