Engine trouble/ question
Old Apr 21, 2010 | 05:30 PM
jbe123's Avatar
Default Engine trouble/ question
So my engine is tapping again..exactly what killed my last engine. Is it normal to have to adjust lifters occasionally? I have about 7000 miles on this engine. And can running this engine with straight pipes and the timing off make my motor does this? It's fixed now but could that of been it? I understand on an engine with roller rockers and aluminum heads and everything but I have a crate motor from summit and it's just a run of the mill 350 all stone stock. So how do I fix it?
Old Apr 21, 2010 | 07:05 PM
Not unusual to have to adjust lifters after breakin, as that's when most of the initial wear occurs. Were the lifters adjusted when you first started or installed the engine? Once you've finished breakin, then one adkust should last a very long time if done properly, and you have hydraulic lifters. Solids will require adjustment more often.
Old Apr 21, 2010 | 07:46 PM
jbe123's Avatar
Alright thanks, the motor came completly assembled minus an intake, fuel pump, etc. I'm just going to get my brother to look at it I guess. What's the proper way of adjusting them? If it's just one should I adjust them all or just that one? Thanks a lot guys.
Old Apr 22, 2010 | 09:40 AM
jbe123's Avatar
I'm pretty sure the only thing that had to be adjusted when the motor was put in was the timing and the carb so I guess it's not unusual for this to happen. And I mean I do get on it from time to time bur I sure so not rag on my car and I just hope it's not going to do what it did last time. Last time they had to adjust it so much that my cam live basically just rounded out..
Old Apr 24, 2010 | 06:51 PM
18436572's Avatar
worst thing is ... if you need to tighten your ajustment , your cam has worn.
if you need to keep re-ajusting. that's a tell tale for a fast wearing cam. check your oil for excessive fillings.
if so .
suspect bad break in or just not enought lub at start up.
did you prime the oil pump before firing?
it could be a bad cam. i heard of a bunch of guys having bad cams. but never seen one.
Old Apr 25, 2010 | 08:21 PM
jbe123's Avatar
Yes this will be my second "bad" cam if this is what it turns out to be. Oh well, guess I'll just build my motor to eat up my friends ls2 goat haha
Old Apr 27, 2010 | 05:42 PM
18436572's Avatar
just a shot, are the lock nuts lose? and backing off...
i doubt it. only seen that on 2.2L with aluminum rocker nuts!
Old Apr 28, 2010 | 12:50 PM
jbe123's Avatar
So I got it fixed it just needed to be adjusted a little. The majority of the noise was coming from my header gasket. So I replaced both of them and bow it sounds great again. Guess I was just paranoid
Old Apr 30, 2010 | 05:47 PM
18436572's Avatar
lol,
i don't know how many times i've seen that!
never think to ask if it's leaking. hope you got a real good set! darn hearders seem to warp soo much from the heat cycles that they blow them out in no time. top and bottom
Ardusv
Jan 6, 2013 09:41 AM
Daedric Kiryu
82-92 V6 Tech
Jun 9, 2010 04:00 PM
slyash50@hotmail.com
Apr 22, 2010 10:28 PM
Cappi
Dec 20, 2009 07:11 PM
chazsmith82
Mar 29, 2009 06:32 PM
