350 engine trouble
Old Apr 18, 2010 | 11:30 PM
slyash50@hotmail.com's Avatar
Default 350 engine trouble
http://www.facebook.com/album.php?ai...2&id=836485111
hey, a few years ago i had a 350 rebuilt, as far as i know everything was replaced except the crank. The cylinders were also bored 0.004 over size, I recently started it up after preoiling it, and heard a knock traced it back to the oil pan so i ripped the motor out, to check the bearings and both main and connecting rod bearings are in rough shape and the pistons are burnt up a bit i just want want to know what you all think, thanks for the input.
Old Apr 19, 2010 | 12:09 AM
I think it needs to be rebuilt.
Was this a "not run yet until now" rebuilt engine? Or was it "rebuilt, driven for a while, then sat for a while" engine?
Old Apr 19, 2010 | 12:12 AM
it was rebuilt drivin for a while then stored
Old Apr 19, 2010 | 12:52 AM
Whether the engine was "put to bed" properly or not could have made a difference.
Also where you said "as far as i know everything was replaced except the crank". That "as far as you know" part is important information, to know for sure what you received.
Old Apr 19, 2010 | 01:23 PM
ok so.. the pistons,connecting rods, lifters, timing gear and chain, the rest was reused and as for putting it to bed.. didnt do a thing it just sat
Old Apr 19, 2010 | 05:03 PM
GRIFF's Avatar
If the pistons are "burnt up a bit" and the bearings are shot it could have been a detonation issue.
Old Apr 19, 2010 | 07:41 PM
yeah that it is what i am starting think. but i will end up bring it to a machine shop see if the block is even any good!
Old Apr 21, 2010 | 11:19 PM
383Stro's Avatar
How bad were the bearings? Could you see copper? Was the motor put together balanced? Does it look as though the bearings are deeply scratched like something (Metal, sand and dirt) was passing through? How bout the rods did any of them look dark and burned down by the crank journals? The sides of the pistons, around the top, just before the rings, how did this area look? Post some pics. Would be great.
Old Apr 22, 2010 | 10:28 PM
hey that face book link is the pics sorry its the only way i could figure it out haha.. but ya the bearings were copper and scratched the sides of the pistons were fairly clean but the tops were dark .. and i did get it over to the machine shop and the guy over there was telling me that it looks like an overfueling problem (to much gas in the oil) he figures that the fuel pump was leaking in to the block. Or that the carb was dumping to much fuel in there apparently the edlebrock carbs are set for sea level and where i am located it needs to be re jetted. either way any one have experience in over fueling
Ardusv
Jan 6, 2013 09:41 AM
Daedric Kiryu
82-92 V6 Tech
Jun 9, 2010 04:00 PM
Barnett1217
Mar 6, 2010 01:14 PM
chazsmith82
Mar 29, 2009 06:32 PM
z28child
Jun 22, 2006 09:48 PM
