engine trouble
Old Mar 4, 2010 | 11:37 AM
Barnett1217's Avatar
Default engine trouble
i drive a 92 rs when i first get in the car and start driving it drives fine about after about 5 to 10 mins. it starts to drive really rough. it gets really jerky and i dont kno y. any advice would be apprecaited thanks.
Old Mar 4, 2010 | 08:04 PM
microkid's Avatar
March 2011 ROTM
Technical User
need more info. what are the gauges telling you? check engine light? any service history? speeds that the issue starts?
Old Mar 5, 2010 | 01:16 AM
No service lights come on, and my rpm gauge bounches around alot. I havent had any work done. It will do it no matter what speed basiclly from the time i put my foot on the gas till i take it off, and it doesnt matter what gear im in. Does this help any?
Old Mar 5, 2010 | 06:36 AM
MegametedK's Avatar
Sounds like fuel delivery to me.
Change the fuel filter 1st & see if there is any change in behavior.
That is easy to do and relatively cheap.
BTW, how does the air filter and crankcase breather element look?
Old Mar 5, 2010 | 07:21 PM
microkid's Avatar
March 2011 ROTM
Technical User
i strongly recomend doing a tune up. plugs, wires, cap, rotor, air and fuel filters, and cleaning the throttle body. once you finish all that, see if that helps with the issue at all. sounds like it could be misfiring. what is the idle speed on the tach?
Old Mar 6, 2010 | 02:42 AM
ive changed the plugs and the wires i just gotta get to the other stuff now. when i first start it up it goes to about 2000 then drops after about 20 to 30 sec. after that it varerys between 1500 and 1000
Old Mar 6, 2010 | 09:04 AM
Which engine do you have...V6 that has FI, or V8 that has TBI?
Old Mar 6, 2010 | 01:14 PM
the v6.
Ardusv
Jan 6, 2013 09:41 AM
Daedric Kiryu
82-92 V6 Tech
Jun 9, 2010 04:00 PM
slyash50@hotmail.com
Apr 22, 2010 10:28 PM
chazsmith82
Mar 29, 2009 06:32 PM
z28child
Jun 22, 2006 09:48 PM
