weird noises from rear end. winding down
Old Apr 9, 2013 | 01:52 PM
Mojo925's Avatar
Default weird noises from rear end. winding down
So i have a 1979 base Camaro and whenever I slow down i hear a whirling/winding down noise, doesn't matter the speed but at higher speeds it's more notable but it's always present. Any ideas?
Old Apr 9, 2013 | 02:07 PM
Rear gear whine perhaps. Have you checked the oil level in the rearend? Some aftermarket gears whine by nature, so it could also be that if a previous owner did a gear swap. This of course is assuming it's a gear whine you're hearing, but I can't hear it from here!
Old Apr 9, 2013 | 04:01 PM
Mojo925's Avatar
Yeah i check all the fluids and those are good all the way around the car. The gears SHOULD be original as far as i know. So should i replace them and if so what gears specifically
Old Apr 9, 2013 | 09:04 PM
v8chvyguy's Avatar
In my line of work, we call it "coast howl" as the bearings wear, the relationship (alignment) between the ring gear and pinion gear changes, causing the noise you're hearing. As with 69, I can't hear it either. If you know the rearends history, it would be helpful. Backing up 69's statement, I have had some gearsets set up perfectly and still make noise.
Old Apr 10, 2013 | 01:59 PM
Mojo925's Avatar
It something i should be really concerned about? I'm assuming the rear end is totally stock and never needed with. I'm doing the rear leaf springs and was wondering if I should do the bearings at the same time and maybe install posi and different gears.
JayJay7051
Dec 9, 2010 05:04 PM
Dillon5224
Oct 26, 2009 09:09 AM
black95z28
Jun 9, 2009 03:37 PM
929BEATSTI
Sep 2, 2007 10:12 PM
