79 Camaro Project
#242
lol, that is just too funny. I wanted a 7/8" bar, but this will do for now. I still need the brackets to mount it to the frame. Bushings are easy. Pete at FBodyWarehouse over at CamaroClub.net may be able to help me out. Hopefully.
#244
![](http://i2.photobucket.com/albums/y20/sevver/IMG_3021.jpg)
That is what I need. They don't need to be gold though.
#246
The patch looks great! I use self tappers all the time for patches. I know the big time guys use those special clamps, but I don't care for them as they require a pretty good sized hole to fill.
My rear swaybar is from a '79 TA and it's 7/8". My stock front is 1" for a BB engine car.
#247
I've always heard you have to match swaybars to each other. Not necessarily like a 1 inch front = 1 inch back or anything like that but that if they don't work with each other you could oversteer/understeer in turns from mis-matched setups. There's a couple of roadcourse people on the local forum I go to and I could've sworn they said that.
ATM> If Nomad doesn't hook you up with the brackets I think I might have them. I had a full setup from a 78 Trans Am but I sold the bar and struts for it. I think I still have the brackets for it though and if you need them I'll double check and see if I still have them.
#248
[QUOTE=kyphur;421324]I've always heard you have to match swaybars to each other. Not necessarily like a 1 inch front = 1 inch back or anything like that but that if they don't work with each other you could oversteer/understeer in turns from mis-matched setups. There's a couple of roadcourse people on the local forum I go to and I could've sworn they said that.
QUOTE]
I think you're correct. Swaybars need to work as a set, but what determines the set size? There's things like shocks, weight additions, springs, engine size. Lots of variables to determine, and unless you're really into that it's a guessing game. I've always used the rule of thumb that the front always needs to be larger than the rear, but not by more than 1/4". Had a friend who did autocross and he told me that was what they did. Made sense, as I've never seen a rear larger than the front.
But I've seen many, many cars without a rear swaybar, so I don't think the "matching" thing is really correct. It's more important to keep the rear smaller.
QUOTE]
#250
![Icon Bike](https://camaroforums.com/forum/images/smilies/icon_bike.gif)
