632ci engine installation in 78 camaro
Old Apr 26, 2014 | 05:25 AM
  #221
clacia's Avatar
Hi, thanks for that. I need to ask the builder about the pump. Did not get into this with him. Is it a GM pump? What reason you switched to electric pump?
Old Apr 26, 2014 | 05:27 AM
  #222
clacia's Avatar
Question on water pumps - you can have either hi volume or high flow? Or it is both together?
For what reason you need a high flow / high volume?
Old Apr 26, 2014 | 10:18 AM
  #223
Different name for the same thing.
Old Apr 26, 2014 | 02:26 PM
  #224
clacia's Avatar
And for what purpose you need one?
Old Apr 26, 2014 | 04:37 PM
  #225
Need one what? I don't know what I need? Do you mean a hi flow pump? If so, there are debates both ways that say you do or don't need one. Some people say the faster you flow the coolant, the less time it has to get hot in the engine. Others say don't move it fast, or it wont have enough time in the radiator to properly cool.
I can tell you have had both hi volume, and stock pumps, and honestly never noticed a difference in temperature. Some drag racers run very small radiators and feel they need a hi volume pump to keep coolant circulating and with such small volume, and restricted flow.
Old Apr 26, 2014 | 07:18 PM
  #226
That might be an issue if you weren't running a thermostat, where the coolant is constantly circulating. But with the stat in place (and closed), the coolant remains in the engine and radiator till the stat opens again.
Old Apr 27, 2014 | 10:57 AM
  #227
clacia's Avatar
I was referring to me - if I need a hi volume pump or not. But with all the posts, I can stay with a standard pump.
Old Apr 27, 2014 | 06:00 PM
  #228
Sudstoy's Avatar
The pump I have is the one out of the GM Performance Parts catalogue for the zz572. We decided early on in the build that we were going electric everything, fans, fuel, and water. Also have the GMPP big block fuel pump.
Old Apr 27, 2014 | 09:47 PM
  #229
I wouldn't get too far ahead ordering engine accessories until you've got the engine. Once you have one on order and the maker tells you what comes with it, then you can order parts. Often a complete crate engine comes with water pump, and other parts that you might duplicate by getting ahead of yourself.
Old Apr 27, 2014 | 11:16 PM
  #230
Sudstoy's Avatar
^^ Words of wisdom, that is one of the reason i have doubles on a lot of parts ^^
