632ci engine installation in 78 camaro
Old Jan 26, 2014 | 12:24 PM
  #111
clacia's Avatar
Originally Posted by 77nomad
Solid mounts can be had from summit or Jegs. I have Moroso brand.
Ok Thanks.
Old Jan 26, 2014 | 12:48 PM
  #112
clacia's Avatar
[/IMG]
Hello. Here is some update....
Yesterday I bought the DSE minitubs and some other sheet metal from Classic Industries.
I removed the stock 10 bolt and leaf springs from the rear and installed temporarily the ride tech lower bars and bracket to the 10 bolt to check how much tyre clearance I have left. There is room for 335/30/18.....
I also jacked up the axle to almost ride height to see how it will look.
What do you tell me regard using mounting perches on the new rear end.. Will it look ugly if I use mounting perches and ridetech lower braket (as shown in the photo)?
Old Jan 26, 2014 | 12:50 PM
  #113
clacia's Avatar
Old Jan 26, 2014 | 12:52 PM
  #114
clacia's Avatar
Old Feb 1, 2014 | 05:34 AM
  #115
clacia's Avatar
Hello,
Regarding tyres are Michelin 335/30 ZR18 good? Or shall I go for BFG? Michelin is easier to find over here but BFG is more difficult.
Old Feb 1, 2014 | 09:36 AM
  #116
Pilots are fine
Old Feb 2, 2014 | 04:11 AM
  #117
clacia's Avatar
Ok Thanks.
Old Feb 2, 2014 | 05:06 AM
  #118
Sudstoy's Avatar
If you are tubbing the rear you should be able to fit more then 335s on your car. I have 315s on mine with a stock suspension setup.
Old Feb 3, 2014 | 10:03 AM
  #119
clacia's Avatar
Hi, so you mean you have 315 tyres at the rear without inside tubbing?
But will the tyre fits inside and underneath the fender lip? Is it possible to post some pictures please?
Thanks for your post
Old Feb 3, 2014 | 01:09 PM
  #120
Mine dont, and cant. There is less than 10mm to the leaf spring. The outside is under the wheel lip.
