1980 t-top gears stripped
Old Aug 17, 2017 | 09:16 PM
JD Z's Avatar
Default 1980 t-top gears stripped
As I was working on one of the t-tops, I found that the gears behind the handle have one or more of the gears stripped. As a result it doesn't open and close the bars to lock/unlock the lock bars. Ideas from the group on where to find replacement gears or other ideas?
Old Aug 20, 2017 | 05:15 PM
Zspoiler's Avatar
I haven`t seen any replacement gears, You might try to find a set of damaged "T" tops for parts .O have a set of gears made. Looks at firebirds as well.
Attached Thumbnails 1980 t-top gears stripped-130044932860518017_26257430996_o-1-.jpg
Old Aug 20, 2017 | 07:09 PM
JD Z's Avatar
Thanks Zspoiler. Appreciate your thinking about it. My next step is to find a damaged top to rob them from. The gears mount with two bolts under to weather seal.
Old Aug 22, 2017 | 07:59 PM
JD Z's Avatar
Default Solution found
The fine folks at Fbodywarehouse were able to locate the gears/rods for my tops. I should be driving soon. Thanks Fbody. Justin
joe86
Sep 9, 2010 02:46 PM
baarf
82-92 V8 Tech
Jul 30, 2010 10:31 PM
Cammy 3.8lV6
Jun 22, 2010 11:12 AM
Thoreau
Oct 2, 2009 07:15 PM
Mesosneaky
Jul 9, 2009 06:56 PM
