80 camaro driver door handle
Old Aug 14, 2017 | 09:20 PM
JD Z's Avatar
Default 80 camaro driver door handle
Arm rest, not handle. My 1980 Z back in the mid 80's had this same problem. My new to me 80 Z has the same problem. The driver inside door arm rest pulled loose from the front screw. The previous owner tried as I did back in the 80's to repair it without success. Do you have any tips/tricks to get that front handle to hold? Or do I need to find a new replacement?
Old Aug 15, 2017 | 08:59 PM
Zspoiler's Avatar
There are kits for those,Its more or less a sleeve that fits in the hole.Or you can put a "riv nut" that fits in the hole as well.
Old Aug 24, 2017 | 09:37 PM
JD Z's Avatar
Thanks for the tip. I looked up that repair kit and fabricated one similar. Works well for now.
JonnyCam
Apr 22, 2015 07:47 AM
619Camaro
Apr 22, 2008 06:30 PM
mikescars
70-81 V8 Tech
Apr 11, 2008 04:49 PM
MassholeLT1
Jan 22, 2008 01:28 AM
MassholeLT1
Dec 1, 2007 07:16 PM
