Stripped grooves on window crank
Old Oct 1, 2009 | 01:50 PM
Thoreau's Avatar
Default Stripped grooves on window crank
Hello everyone,
My question today is about my window crank. When I bought the car the crank was removed and they were using vise grips to lower and raise the window. As you can all probably guess, this led to the stripping of the grooves where the window crank would normally go. Now, I am trying to find the easiest/ most effective way to put it all back together how it is supposed to go. Any information will greatly be appreciated.
Attached Thumbnails Stripped grooves on window crank-window-crank-grooves.jpg
Old Oct 1, 2009 | 02:16 PM
Y2K's Avatar
Y2K
Old Oct 1, 2009 | 04:11 PM
Thoreau's Avatar
Thanks for your quick reply. So I do need the whole regulator? I thought I might be able to get off just getting something smaller and cheaper or by rigging something together...
Once again, thanks.
Old Oct 1, 2009 | 08:35 PM
JRs72RS's Avatar
February 2009 ROTM
Which side do you need? I have an extra regulator you can have, just pay the shipping.
Old Oct 1, 2009 | 09:07 PM
Thoreau's Avatar
I need the driver side.
Old Oct 1, 2009 | 11:30 PM
brownstone101's Avatar
i get a new one. mine did the same thing and the whole thing squeeks and grinds and just wore out. whats better than new(ish) goodies for your Fbody? lol
Old Oct 2, 2009 | 07:15 PM
JRs72RS's Avatar
February 2009 ROTM
I have a driver's side regulator. I can get some pics of it if you want. It works great, I can check it over real good and lube the gear and friction spring for you. PM me if you want to get it. Anything else you need? I have a lot of small parts left over.
justinw23453
Apr 7, 2010 01:08 PM
73 T Top
May 2, 2007 08:33 PM
Chappie99
Apr 29, 2007 06:35 PM
t_jnorth
Jun 13, 2006 02:13 PM
t_jnorth
Jun 12, 2006 04:05 PM
