stripped damper bolt!
Old Jul 30, 2010 | 05:57 PM
baarf's Avatar
Default stripped damper bolt!
Any easy fix?
I was installing the new harmonic balancer, yes I was using the right tool, but when I put the bolt back, it stripped the threads on the bolt.
Dang it.......
Old Jul 30, 2010 | 07:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
nothing easy. you can try your best to clean them up or retap it, but i dont think you will find a correct bolt larger to fit it. may have to replace the crank. how did you manage to do that?
Old Jul 30, 2010 | 08:04 PM
ive done it and just ran a tap in it and cleaned the threads up. i did have a extra bolt from another balancer to use that was a little longer. when i put it on i helped the bolt to pull the balancer on by tapping the rachet lightly with hammer as i felt it tighten. that way the bolt was not working to hard when it only had a few threads to pull with.
Old Jul 30, 2010 | 10:31 PM
baarf's Avatar
I used the proper tool of course.
I used a 7/16 20 tap, cleaned out the threads, and it tightened up just fine.
Dodged that one ..............
On the bright side, I am one step closer to getting the engine back in.........
VALHAR
Nov 15, 2014 08:58 PM
kocuba
May 21, 2011 04:04 PM
joe86
Sep 9, 2010 02:46 PM
hipirn
Dec 1, 2007 04:15 PM
hipirn
67-69 V8 Tech
Nov 21, 2007 09:25 PM
