Which damper
Old Nov 18, 2007 | 03:19 PM
hipirn's Avatar
Default Which damper
I need help! Whatdoes the factory 1967 Camaro 350 V8 front engine damper/ Hub? Look like? Is it just a hub? Apparently the 67's are different then all the rest as I don't see anything listed anywhere for replacement for the 67's. I have a "hub" and a 2 tier timing tabfront cover that fits with the hub but don't know if it's correct for this 1967 restoration? Hipirn
Old Dec 1, 2007 | 04:15 PM
1969 SS's Avatar
Default RE: Which damper
doesn't reallymatter unless you are going for a 100 point restoration.
VALHAR
Nov 15, 2014 08:58 PM
tyler_caz18
70-81 V8 Tech
Feb 17, 2014 08:08 PM
baarf
82-92 V8 Tech
Jul 30, 2010 10:31 PM
hipirn
67-69 V8 Tech
Nov 21, 2007 09:25 PM
