Vibration damper stuck on
Old Jan 12, 2014 | 04:02 PM
tyler_caz18's Avatar
Default Vibration damper stuck on
I have been trying to remove the vibration damper on my 454 to put a bigger cam in, but i absolutely cant get it off. i soaked it in pen oil. I thighten it and shocked it with a hammer, i heated it, and i broke 3 pullers trying to get it off. Im starting to get really frustrated and i need some advice before i do something stupid.
Old Jan 12, 2014 | 05:03 PM
Never had one that stubborn before. You are using a dampener puller, not a gear puller?
Old Jan 12, 2014 | 08:14 PM
YAV8's Avatar
With the dampener puller remember to NOT have the three bolts tightened down. Keep is just a little loose and the center bolt floating.
Old Jan 12, 2014 | 09:38 PM
I have been using a vibration damper puller, but i did have the 3 bolt tight. I will try it with the bolts not tight, as soon as my snap on puller comes in.
Old Jan 14, 2014 | 05:13 PM
bowtieguy's Avatar
July 2009 ROTM
Tighten the puller up and tap on the balancer with a hammer and repeat.I have never seen one that requires heat to get it off..Is it a rebuilt motor..has the balancer been replaced.
Old Feb 17, 2014 | 08:08 PM
paperairplanes's Avatar
you could drill it next to the crank to relieve pressure, youd need a new one tho
VALHAR
Nov 15, 2014 08:58 PM
claude1991
Mar 27, 2011 10:39 PM
baarf
82-92 V8 Tech
Jul 30, 2010 10:31 PM
hipirn
Dec 1, 2007 04:15 PM
hipirn
67-69 V8 Tech
Nov 21, 2007 09:25 PM
